both wan lines are 8 Mbps
but when i test on speedtest.net or check the load balance by downloading a file i notice than only wan1 have activity while wan2 is not active for users connected on mikrotik.
/ip route print Flags:
X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 10.0.0.138 1
1 A S 0.0.0.0/0 5.5.5.1 1
2 A S 0.0.0.0/0 10.0.0.138 1
3 S 0.0.0.0/0 5.5.5.1 2
4 ADC 5.5.5.0/24 5.5.5.200 WAN2 0
5 ADC 10.0.0.0/24 10.0.0.100 WAN1 0
6 ADC 10.10.10.195/32 192.168.0.1 0
7 ADC 10.10.10.196/32 192.168.0.1 0
8 ADC 10.10.10.198/32 192.168.0.1 0
9 ADC 10.10.10.199/32 192.168.0.1 0
10 ADC 192.168.0.0/24 192.168.0.1 local 0
/ip firewall nat print
0 X ;;; default internet rule
chain=srcnat action=masquerade out-interface=WAN1
1 ;;; Redirect Expired Pool Users to local Web Proxy for redirecting them to N on Payment Page.
chain=dstnat action=redirect to-ports=8080 protocol=tcp src-address=172.16.1.1-172.16.1.255 dst-port=80
2 chain=srcnat action=masquerade out-interface=WAN1
3 chain=srcnat action=masquerade to-addresses=0.0.0.0 out-interface=WAN2
no i’m not proxy on mikrotik, but i will later after i accomplish the PCC method to achieve 2 wan lines bonding, though all traffic goes through wan1 and wan2 is always on low traffic.
the ip address config was a typing mistake at the forum, check my print in the following post to see my settings., i’m using mikrotik usermanager as well.
If I remember right this was the only way I could get PCC or ECMP to work right. I do know that put the Nth into the mangle rules was the only way I could get though put on both the Upload and Download to work I just don’t remember just which rule I put it in. It will not work if you have 2 wan’s with only 1 gateway IP. I’ve tried it and it didn’t work. I did get it to work but the router I had it on get hit by lighting that night and I did save a backup. Very stupid of me I know.
it gives me (bad command name add (line 1 column 1) on terminal !!
anyway i changed it using winbox gui, it did nothing, WAN2 still have no activity after modifications, all bandwidth goes thruogh WAN1 only
Ok I had the format wrong on it. It should have been nth 2,1 and nth 2,2 I understand you changed it using anther method and it still didn’t work. As I said I lost the copy I had that worked but I do know that when I did get it to work I had to have the nth in there but there was more. I read over my notes and seen that I also had to have 2 nat rules to make it work as well. I just don’t have the details as I have lost them. The only part I have was that one rule forced marked route for wan1 out wan1 and the other out wan2 using the routing marks from the mangle rules. With these rule it would balance the income or download but all the upload would only go though one connection. Both IP’s are on the same subnet with the same subnet. I have requested an IP for the second connection on a different subnet to see if that fixes the issue.
I am working on the same problem now my self. When I find an answer I will post here If you find one that works for you I would thankful if you could do the same.
Syed said he would help when he get some free time.
anyway, have you try bonding interfaces ?
does it merge both interfaces speed into one and make it look like one line with both speeds ?
i did checked the link weeks ago.
while some Egyptians showed that speed merge can be achieved but they are using hotspot for authentication.
i noticed when i go to (IP - Firewall - Connections) that only pppoe users don’t have connection mark (either wan1_mark or wan2_mark) while manually static ip clients have both marks and looks like it applies only on clients with manual ip on their pc’s !!
Well i have PCC configuration and 2 WAN interfaces load balance with one of my clients and it works fine at their local network but i never try PPP connection with this configuration.
I’m originally from Gaza but the whole my life living abroad
