2 wan routing
2 wan interface
1 wan 111.111.111.2/30
gateway 111.111.111.1
2 wan 222.222.222.2/30
gateway 222.222.222.1
1 wan routed 333.333.333.0/24
at 2 wan routed 444.444.444.0/24
ip route print
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 AS 0.0.0.0 / 0 111.111.111.2 111.111.111.1 1
1 AS 0.0.0.0 / 0 222.222.222.2 222.222.222.1 1
check the route from the Internet to 333.333.333.100
tracert 333.333.333.100
Tracing route to 333.333.333.100
with a maximum of 30 hops:
8 15 ms 19 ms 19 ms 111.111.111.2
9 16 ms 20 ms 19 ms 333.333.333.100
check the route from the Internet to 444.444.444.100
tracert 444.444.444.100
Tracing route to 444.444.444.100
9 16 ms 20 ms 19 ms 444.444.444.100
but should
8 15 ms 19 ms 19 ms 222.222.222.2
Change weight
ip route print
0 AS 0.0.0.0 / 0 111.111.111.2 111.111.111.1 2
everything as it should be
I set up routing to PREF-SRC consistent route?
2 wan интерфейса
на 1 wan маршрутизируется 333.333.333.0/24
на 2 wan маршрутизируется 444.444.444.0/24
ip route print
0 A S 0.0.0.0/0 111.111.111.2 111.111.111.1 1
1 A S 0.0.0.0/0 222.222.222.2 222.222.222.1 1
проверяю маршрут из интернета на 333.333.333.100
Трассировка маршрута к 333.333.333.100
с максимальным числом прыжков 30:
проверяю маршрут из интернета на 444.444.444.100
Трассировка маршрута к 444.444.444.100
а должно быть
меняю вес
ip route print
0 A S 0.0.0.0/0 111.111.111.2 111.111.111.1 2
все как и должно быть
как мне настроить маршрутизацию чтобы PREF-SRC соответствовал маршруту?
uh?
hi,
from the output here :
but should
since you have 2 default route from those 2 WAN (forming load balanced gateway) - i think you need a policy-based routing (PBR) to redirect any traffic to 444.444.444.0/24 to be exit/enter using the WAN #2.
the documentation on mikrotik PBR is here : http://www.mikrotik.com/testdocs/ros/3.0/ip/route.php
HTH.
Unfortunaly it does not work fully
in this case
8 * * *
but the gateway is not defined when tracing
and go to the mikrotik can not through webmin
also do not know how this will affect the account of the traffic netflow
How else can send packets to the correct route?
in addition to PBR, add src-NAT rule to masquerade router’s traffic with output-interface=wan2
in local process routing decision, wan1 is selected as default route (w/o routing-mark), with pref-src=IP_of_wan1. after routing adjustment, default gateway is changed to wan2, but src-ip remains the same
but I have no gray IP
only the real IP
sure. but as far as I understand, you need to masquerade one public IP with another one for second uplink
