Hello to everybody!
I have the following setup (see picture attached to this post):
- The Technological WAN connected to port 1 of my router. (192.168.0.0/24)
- The Data WAN (the one that will provide the internet) connected to port 2 of my router. (192.168.1.0/24)
- 4 PLCs.
- 1 SCADA PC.
- WiFi access for my laptop, for diagnosis and maintenance purposes.
What I did:
- Setup (in quick access) the IP of my router as 192.168.0.211 and the gateway as 192.168.0.1.
- Port forwarding on port 502 to PLC2 (192.168.222.202) for a Modbus TCP connection - a Master from the technological WAN connects to my PLC to read/write data via Modbus TCP/IP.
So far, so good.
What I must do:
- Create a connection to the internet, via Data WAN and allow access to the internet only for the SCADA PC and via WiFi (hidden SSID).
- Create port forwarding from Data WAN to SCADA PC for VNC ussage.
- Setup the router for a VPN, in order to connect remotely to the LAN, for debuging purposes.
- Without question, the internet from WAN 2 should not route to WAN 1.
Could someone help me setup my router accordingly?
Best regards,
Voicu.
