Hi All,
I have a RB750UP box, and have just gone from a single DSL connection to 2 shiny new 100/50 Fibre connections.
I currently have 2 supplied routers from the ONT and fed in to the Mikrotik, only one connection is being used ( just connected a couple of hours ago ).
My ISP says I can ditch their routers if I tag the incoming connections with a VLAN 10. GREAT, if I knew how to set that up.
Can some one please explain how I set up the following ( ideally in winbox, but I guess it would be a good time to learn the CLI too ):
port 1: WAN 100/50 connection 1 ->default connection, for all desktops and Wifi AP’s.
port 2: WAN 100/50 connection 2 ->servers and voip lines
port 3: LAN → switch → local network: 192.160.10.XXX
port 5: PoE IP Camera ( local only )
Mikrotik → 192.168.10.1
Servers → 192.168.10.10-192.168.10.20 ( connection 2 )
IP Phones → 192.168.10.30-192.168.10.45
Static Desktops → 192.168.10.50-192.168.10.70 ( connection 1 )
DHCP → 192.168.10.100-192.168.10.200 ( connection 1 )
VPN DHCP → 192.168.10.201-192.168.10.240 ( connection 1 - I think )
