2 x RB133C PTP bridge problems
i am trying to setup a wireless bridge to connect a DVR (mounted 300m away in a barn) to my home network.
I am using 2 x RB133CS with 5.26 firmware and tp-link dualband cards. For now i setup the devices just for test purposes.
Device 1 - connnected to my adsl modem
[admin@AP] > /interface wireless print
0 R name=“wlan1” mtu=1500 mac-address=D8:5D:4C:8A:40:18 arp=enabled
interface-type=Atheros AR5413 mode=bridge ssid=“Test_AP” frequency=5300
band=5ghz-a channel-width=20mhz scan-list=default wireless-protocol=any
antenna-mode=ant-b wds-mode=disabled wds-default-bridge=none
wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
hide-ssid=no security-profile=default compression=no
Device 2 - currently connected to my pc and wirelessly device 1
lags: X - disabled, R - running
0 R name=“wlan1” mtu=1500 mac-address=D8:5D:4C:89:87:76 arp=enabled
mode=station-bridge
ssid=“Test_AP”
frequency=5180
band=5ghz-a
channel-width=20mhz
scan-list=default
wireless-protocol=nv2-nstreme-802.11
antenna-mode=ant-b
wds-mode=disabled
wds-ignore-ssid=no
bridge-mode=enabled
hide-ssid=no
security-profile=Test compression=no
For surfing i have no problems and also a speedtest shows some 14 mbps up/download wich is ok on a 15 mbps line:)
the problem is that youtube videos won’t load, wich can be a sign that viewing the cameras attached to the DVR won’t work as this is also streaming i suppose
what could be the cause of this?
I am coming with new information,
  1. I have tested a the download speed from my network with the following setup:
my PC - switch - AP +++wireless+++ station ----IP phone ---- PC
File : 640 MB iso, download speed about 2.0x MB/s shown in winbox as 18-19 Mbps
talking on the phone was also possible without any hickups.
Update: I tried to view youtube directly over UTP wire and I have the same problem…so I think this topic is solved.
Thank you.
