2 xr2 cards one rb133
I HAVE TWO CLIENTS HARD TO REACH, WITH A 24DBI ANTENA TOWARD EACH ONE I AM USING A 1 WATT AMP WITH A TELETRONICS AP AND A SPLITTER. I DONT WANT TO USE THE AMP. WILL IT BE BETTER IF I USE AN RB133 WITH 2 XR2 CARDS ONE TO EACH ANTENNA OR SHOULD I USE UNE RB133 FOR EACH CARD.
THANK YOU
To go along with this question: Will 2 XR2 or XR9 cards fit in the “stacked” minipci slots on the RB133?
Both the amp and the splitter would be good to get rid of if you can get adequate signal with the XR cards. Is 900 Mhz an option for you or do you prefer to stick to the 2.4?
THANK YOU FOR ANSWEARING.
I CAN INSTALL ONE XR2 IN ONE OF THE TWO SLOTS ON TOP OF RB133 AND ONE ON THE BUTTOM.
WILL THEY WORK TOHETHER BEING THAT CLOSE AND IN THE SAME BAND??
WILL THEY INTERFER EACH OTHER?
