20 KM wireless Link
Hello Guys,
I want to know which model works well for 20km range link in 5ghz band? I am thinking to use QRT 5ac series for that PTP link. Let me know if that works or suggest some other models that can work.
Thanks,
https://mikrotik.com/calculator
Here you can play with diferent antenas
How much bandwidth is needed, how much power could you user (country)
I don’t need more than 10M. I live in USA and we could go up to 30dbm Tx power.
I don’t know how accurate is this for 20km link.
For an estimate in good weather, it is accurate enough. Just remember that you need line of sight. The antennas must be high enough.
