200 Mb/s synchrone Fiber and Mikrotik
Hi, I have a 200 Mb/s synchrone filber internet line from my ISP.
Is mikrotik suitable for this speed?
What device do I need? I have a Fiber modem so I need only UTP and Wireless.
Allso the Wireless must be fast.
What is the speed of Wireless with Mikrotik?
For a home setup? Upcoming RB3011 will be ideal. RB2011UiAS-2HnD would be the minimum I’d get.
2011 is enough it’s wireless also is enough. Problem would be with cpu hungry operations like firewalling and queuing. But your speed is achievable with this device if there will not be any other special requirements.
Hi thanks for your reply.
The device is only for a few Wired connections and about 5 to 10 Wireless devices.
No firewalling. Maybe only DHCP server.
Can a RB951G-2HnD do this also? Or is this not a good idea?
Main thing is that the wireless speed is good.
Yes , it will probably cope with 200Mbps, for sure if you use fasttrack (no firewalling = ideal situation for fasttrack) plus it has one of the better radios for 2.4GHz APs.
You insist on wireless speed, why? What is needed?
By performance are both devices the same. 2011 has better antennas. Both are enough for you. Wireless is question of your local situation mainly.
