200 users what can i do
hey
i have about 200 user
and i have 6 dsl line all if the 2mb
my topOlogy like that
wan1
wan2
wan3
PCC (3.30) ------- HOTSPOT 3.30 ----SWITCHES
wan4
wan5
wan6
what is the best for me
pcc . nth
and what can i do coz every one say it slow internet
and skype, online game give me DC
MY 6 LINE IS PERFECT
I WANNA THE BEST CONFIGURATION FOR ME
THANX
Bond them together if you can (if your ISP will do that). That will give you 12mbps. Then, use PCC.
What PCC settings are you currently using?
EDIT: I meant to say “Then, use PCQ”. PCQ is a great way to share bandwidth fairly.
i dono any thing about bonding plz explain and how can i know if my isp aloow bonding or n't
my pcc config
[adminxx@MikroTik] > ip
[adminxx@MikroTik] /ip> f
[adminxx@MikroTik] /ip firewall> ma
[adminxx@MikroTik] /ip firewall mangle> ex
jul/12/2012 00:34:32 by RouterOS 3.30
software id = TKAI-9XV3
/ip firewall mangle
add action=mark-connection chain=input comment="" disabled=no in-interface=wlan1 new-connection-mark=wlan1_conn
passthrough=yes
add action=mark-connection chain=input comment="" disabled=no in-interface=wlan2 new-connection-mark=wlan2_conn
passthrough=yes
add action=mark-connection chain=input comment="" disabled=no in-interface=pppoe-out3 new-connection-mark=wlan3_conn
passthrough=yes
add action=mark-connection chain=input comment="" disabled=no in-interface=wlan4 new-connection-mark=wlan4_conn
passthrough=yes
add action=mark-connection chain=input comment="" disabled=yes in-interface=wlan5 new-connection-mark=wlan5_conn
passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=wlan1_conn disabled=no new-routing-mark=wlan1
passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=wlan2_conn disabled=no new-routing-mark=wlan2
passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=wlan3_conn disabled=no new-routing-mark=wlan3
passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=wlan4_conn disabled=no new-routing-mark=wlan4
passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=wlan5_conn disabled=yes new-routing-mark=wlan5
passthrough=yes
add action=accept chain=prerouting comment="" disabled=no dst-address=192.168.12.0/24 in-interface=Local
add action=accept chain=prerouting comment="" disabled=no dst-address=192.168.4.0/24 in-interface=Local
add action=accept chain=prerouting comment="" disabled=no dst-address=192.168.5.0/24 in-interface=Local
add action=accept chain=prerouting comment="" disabled=no dst-address=192.168.6.0/24 in-interface=Local
add action=mark-routing chain=prerouting comment=TUBEEEE-download-list disabled=no dst-address-list=TUBEEEE-download-list
new-routing-mark=wlan5 passthrough=no
add action=mark-connection chain=prerouting comment=2 disabled=no dst-address-type=!local in-interface=Local
new-connection-mark=wlan1_conn passthrough=yes per-connection-classifier=both-addresses-and-ports:4/0
add action=mark-connection chain=prerouting comment=1 disabled=no dst-address-type=!local in-interface=Local
new-connection-mark=wlan2_conn passthrough=yes per-connection-classifier=both-addresses-and-ports:4/1
add action=mark-connection chain=prerouting comment=4 disabled=no dst-address-type=!local in-interface=Local
new-connection-mark=wlan3_conn passthrough=yes per-connection-classifier=both-addresses-and-ports:4/2
new-connection-mark=wlan4_conn passthrough=yes per-connection-classifier=both-addresses-and-ports:4/3
add action=mark-routing chain=prerouting comment="" connection-mark=wlan1_conn disabled=no in-interface=Local
new-routing-mark=wlan1 passthrough=yes
add action=mark-routing chain=prerouting comment="" connection-mark=wlan2_conn disabled=no in-interface=Local
new-routing-mark=wlan2 passthrough=yes
add action=mark-routing chain=prerouting comment="" connection-mark=wlan3_conn disabled=no in-interface=Local
new-routing-mark=wlan3 passthrough=yes
add action=mark-routing chain=prerouting comment="" connection-mark=wlan4_conn disabled=no in-interface=Local
new-routing-mark=wlan4 passthrough=yes
add action=mark-routing chain=prerouting comment="" connection-mark=wlan5_conn disabled=yes in-interface=Local
new-routing-mark=wlan5 passthrough=yes
add action=mark-routing chain=prerouting comment=20.20.20.1 disabled=no dst-address=20.20.20.1 new-routing-mark=wlan5
passthrough=no
add action=mark-routing chain=prerouting comment=192.168.11.1 disabled=no dst-address=192.168.11.1 new-routing-mark=wlan5
passthrough=no
add action=mark-routing chain=prerouting comment=192.168.4.1 disabled=yes dst-address=192.168.4.1 new-routing-mark=wlan2
passthrough=no
add action=mark-routing chain=prerouting comment=192.168.6.1 disabled=yes dst-address=192.168.6.1 new-routing-mark=wlan4
passthrough=no
add action=mark-routing chain=prerouting comment=192.168.7.1 disabled=no dst-address=192.168.7.1 new-routing-mark=wlan5
passthrough=no
add action=mark-routing chain=prerouting comment=192.168.9.1 disabled=no dst-address=192.168.9.1 new-routing-mark=wlan5
passthrough=no
add action=mark-routing chain=prerouting comment=192.168.12.1 disabled=yes dst-address=192.168.12.1 new-routing-mark=
wlan1 passthrough=no
U WIL FIND THAT I HAVE JUST 5 WAN COZ IM ON X86 N'T ROUTER BOARD
I CONECT TOW X86 PC
TO HAVE ENOUGH WAN ( NIC ) AND I MAKE YOUTUBE ON SPECFIC WAN (( WLAN 5)
. ##################### . WLAN1 |
.##################### . WLAN2 |
.#####################. WLAN3 |----- PCC X86---- HOSTSPOT X86
.##################### . WLAN4 |
. WLAN 7 --X86 PCC-----WLAN5 |
#####. WLAN8------
WLAN5 FOR YOUTUBE ONLY
I TRY TO GET ALLMOST IP ADDRESS OF YOUTUBE AND I MAKE IT PREROUTING ON WLAN 5
PLZ HELP ME ITS SO HUGE ON MY experience
To find out if they allow bonding (MLPPP), call them and ask them :slight_smile: It must be done on THEIR side and YOUR side, on BOTH sides.
Here is how it works:
http://wiki.mikrotik.com/wiki/Manual:MLPPP_over_single_and_multiple_links
Here is an example:
http://forum.mikrotik.com/t/mlppp-between-two-mt-routers-using-3xsdsl-and-a-housing-isp/27274/5
If they won’t do it, you can still do load balancing:
http://wiki.mikrotik.com/wiki/Load_Balancing_over_Multiple_Gateways
About the PCC… I mean’t “PCQ”! PCQ queues is the best way to do fair speed balancing among your customers, to keep it fast for everyone.
THANX
I WILL ASK THEM
BUT ABOUT YR EXAMPLE OF LOAD BALANCING I WAS WORKING FROM 2 YEARS BY THIS WAY
BUT I THINK PCC IS GREAT .??!!
WHAT IS THE BEST FOR ME AND IS THIS SPEED (( 12 MB )) IS enough for 200 user ???
12mb is very low for 200 users. If they all use it at the exact same time, that would be 0.06mb each!
If a handful of people watch movies, that’s 12mbps right there.
