200mb-3km configuration(noob)
good day all
i have 2pcs XST hgnr2 connected successfully at home but the signal is poor when mounted 3 km apart .
the question is : will they transmet internet that far ? and how much i would get max ?
other qustion is what mode to choose , station , station bridge , cpe station wds .. and so on .
i did googled alot and found lots of information with different configurations that made me confused .
thanks
Sxt5hndr2?
I think he meant RBSXT-5nDr2, that thing should be good for 10km, I personally never gave it a try, but by the specifications and by some posts here it seems possible. I would use CPE for this.
Maybe this will help you: http://forum.mikrotik.com/t/routerboard-sxt-what-max-distance-with-max-thr-put/44362/1
100mbit Ethernet port cannot provide 200mbit throughput in one way.
