2011-uas LCD missing commands
running verision 5.26 of a RB2011UAS-2HnD,
my /lcd commands are only
/lcd
.. – go up to root
edit –
export – Print or save an export script that can be used to restore configuration
get – Gets value of item’s property
print – Print values of item properties
reset-calibration –
set – Change item properties
is this normal ?
i need to change the interface from spf1 to ether1
Try upgrading to 6.4.
where can i see differences in 5.25 and 6.xx ?
http://www.mikrotik.com/download/CHANGELOG_6
http://www.mikrotik.com/download/CHANGELOG_5
lol been there done that, i meant any features in 6 not in 5 one would need a comparative table to see benefits, else why upgrade ?
do new devices come with 6 ? is 6 beta ?
6 is not beta, it is stable and I have installed it on thousands of routers. Read through the changelogs, those are the differences. No table exists.
