I’m having a problem getting my Andriod phone working with a 2011 for USB teathering. The same phone works well with the CCR we have in the office, but when I try to use a 2011 for some testing with the teathering feature, it does not work.
I have tried turning off the power to the 2011 without the USB plugged in, and then plugging the USB into the router and turning it on. When I do that, sometimes the router goes into a reboot loop for a bit. Otherwise when I enable teathering on the phone, it says that it is turned on, but the LTE interface does not show up in the 2011 like it does in the CCR. The Bugfix chain does not go into the reboot loop from what I can tell, but Current and RC do.
Does anyone have any suggestions, or have USB teathering working on their 2011? If you could supply any hints, it would be greatly appreciated. Thanks!
