2011UAS-2HnD-IN - Antenna hole dimensions
I’m considering changing the Antennas on a 2011UAS-2HnD-IN as I only require the Wifi for very short range and the factory fitted are a little long and in the way.
Can any one tell me or estimate the hole cut-outs for the factory fitted antenna so I can find something similar?
