2011UAS-2HnD-IN load balancing
Hi guys
I am getting a 2011UAS-2HnD-IN in the next few days, and I am hoping to configure it on a dual WAN connection (one PPPOe client based connection and 1 DHCP connection), using PCC for load balancing.
My question is: Is it possible to have PCC load balancing between two WAN connections, but ALSO perform some basic policy based routing[which would take precedence on the load balancing I guess], as there is a host on the LAN that I need to force to use a specific WAN for all connections? Is is just a question of order of rules?
K
I forgot I have another query re load balancing :slight_smile:
Assuming I configure PCC based on source iP-destination IP pair (so that FTP and forums work…), is it still possible to have a specific connection (based on destination IP and port, such as 443) to load balance between the two WANs?
Effectively, this rule will take precedence over the PCC rul(es) to allow load balancing even if the source ip/destination IP remain the same?
Thanks again
K
