2011UiAS-2HnD constantly dropping connections
Our Mikrotik router has beed constantly dropping wireless connections for the las few months. We have 10-20 notebooks using wireless connections and about the same number of android devices. Every few minutes some devices disconnect and take some time to connect again (disconnected, reassociating, connected loop in log). Even devices close to router (about 3m) have this problem.
What can be the cause of all those disconnects?
I've seen similar topics earlier, used some solutions (disable tkip, set group key update to 1h, set dhcp lease to 1d), but no success.
Config:
-guest network on virtual-AP has been set this week, so it is not source of problem
-I've started adding notebook MACs to access-list to disable default-authentication later - too cut all android devices from network.
-I've set static IPs for all company notebooks
Log:
IP settings have nothing to do with disconnects.
The WiFi disconnects are on L1 or L2. IP get’s in the picture on L3.
You should have a look, how many other routers, devices etc… are in the vicinity of your clients. Use InSSID-er to see what channel is the least congested.
