I just received my router and I powered it on and it was first stuck in ether boot. I consoled in and fixed that portion of it and set it to NAND boot. It got to the loading Kernel and stuck and no message after that. I figured I would go ahead and Netinstall the latest version. I have been having issues with that as well. First I got 3.10 and 3.18 to install but when booting it shows:
Then half the time when doing installations I get:
I also noticed when I think everything is installed and well after starting services it says:
system halt
Like I said I have been messing with it for about 4 hours. I have upgraded the latest RouterBOOT firmware on it and still no luck. I have NetInstalled the minmum and still have issues.
I am trying to contact the reseller and get a RMA started but haven’t heard back. I would love to be able to fix it if possible but I am having some major issues doing anything. The one time I did get it to “work” I went to configure the Wireless Interface and after I clicked apply the interface just disappeared.
Any thoughts would be helpful. Thank you in advance.
