I observe very poor performance with 2011UAS-2HnD-IN: signal level is usually high, but it drops randomly several times a minute, then in a second or two returns to the normal values. During the signal drop I see packet loss or long delays.
What is the possible reason and how I can fix the issue?
Signal & SNR graphs attached. RouterOS 6.9
Wi-fi config:
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode band=2ghz-b/g/n basic-rates-a/g=6Mbps,9Mbps,12Mbps basic-rates-b=“” bridge-mode=disabled country=russia disabled=no frequency=2437
frequency-mode=regulatory-domain ht-basic-mcs=mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs=
mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23 l2mtu=2290 mode=ap-bridge name=ngx2 preamble-mode=long rate-set=
configured ssid=ngx2 supported-rates-b=“” wds-default-bridge=bridge-local wireless-protocol=802.11
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa2-pre-shared-key=XXXXXXXXXX
/interface wireless registration-table> print stats (for one client)
5 interface=ngx2 mac-address=7C:D1:C3:EE:89:39 ap=no wds=no bridge=no rx-rate=“130.0Mbps” tx-rate=“130.0Mbps” packets=1308,1395 bytes=535958,155615 frames=1308,1397 frame-bytes=538570,147481 hw-frames=1790,1942
hw-frame-bytes=818323,216409 tx-frames-timed-out=0 uptime=3m3s last-activity=10ms signal-strength=-48dBm@6Mbps signal-to-noise=57dB signal-strength-ch0=-56dBm signal-strength-ch1=-49dBm
strength-at-rates=-50dBm@1Mbps 42s610ms,-48dBm@6Mbps 10ms,-45dBm@HT20-2 14s50ms,-45dBm@HT20-4 12s590ms,-45dBm@HT20-5 920ms,-45dBm@HT20-6 990ms,-45dBm@HT20-7 10ms tx-ccq=88% p-throughput=92290 distance=2
last-ip=192.168.43.190 802.1x-port-enabled=yes authentication-type=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm management-protection=no wmm-enabled=yes
