we have received RB 2011UiAS today. With ROS 5.26 i can not connect winbox via eth1-5. it shows the mac address etc. when winbox is looking for devices but nothing happens. the link lights come on however. on eth6-10 i have no link lights but winbox works. what is the problem here, what can i do to fix this ?
also the LCD stays on the ‘loading kernel from nand’ screen, what are the correct settings to make the LCD work ?
I don’t want to use v6 because we intended to replace faulty RB450G with the RB2011 which have a v5 configuration. Also when I chose the mipsbe platform in your download section I am offered v5 and the RB2011 is listed.
Our attempts to upgrade existing v5 routers to v6 have not been successful. There are to many changes apparently.
V5 is supported only for first rb2011. You have latest revision of rb2011. It is supported only in V6.
Install 6.5 and then import configuration from V5
