I know this is far than the best you can find in this forum, but … it’s a kind of success, considering everyting. Here are the specs.:
Point A:
ASUS MB running Intel 1,6 GHz, 512 Mb RAM, FlashDisk
CM9 and MT’s R52 wireless cards on 5GHz dual polarity dish 32dbi
Point B:
ASUS MB running Intel 2 Ghz, 512 Mb RAM, FlashDisk
Distance is 22,5 km, the link is running NStream Duo at 5 Ghz, 20 MHz channels. Rx signal: - 64 dBi (VPol), Tx signal: - 56 dBi (HPol), Rx/Tx rate: 48 / 54 Mbps
The results were messured while the link was already operational and troughoutput we got was Rx/Tx: 21 / 32 Mbps UDP and 21 / 29 Mbps TCP. This has been measured with bdw test running both directions - most realistic results, as far as I can say.
The line of sight is almost clear, if we exclude a large Telecom’s tower standing just about in the middle, between the points. Tx and Rx signal strengths might look good, but these are 32dbi parabolic dishes (300 EUR’s each !!!), with just 4 degrees focus. There is a high level of noise present at point A, but I am still not too happy with VPol results. Will try to tune it some more later …
Anyhow, I was hopping but sincerely not expecting better results than these. Surelly 40 Mhz channels will give much better results, but than again, I fear it will cause problems to some guys having link(s) at the same site … we’ll see. So far, I’m trying to be a good neighbour.
OK. That’s it. Your coments please.
