24 volt on rb 133
Can power RB133 with 24-26 volt?
specifications claims max voltage 28 volt, but power supliess in market for these boards are 18 volt
can power it with these voltage without risk?
regards
jose
Jose, there should not be any problems, if this data is mentioned at specification.
If you will have any problems, you have to report them.
It works fine with 24V buffered power supply.
Hi there, we feed some of our RB133’s between 20v - 27.4v (Depending on battery float at remote locations) and they all run with no problems.
