2402, 2404... non-standard 2.4 channels
Dear RouterBoard users:
We have a problem to use non-standard channels such 2402, 2404 and 2499???
The performance is not stable at all on these new channels!! Any one successfully use these channels??
Where do you came from? Some frequencies that are in 2,4GHZ specturm are used in commercial applications such as public telephony, security channels, TV retransmitters, bluetooth devices and many many more. And in some countries such as France using low and high channels are prohibited. To use them you have to buy a current licence, buy surely you’ve never get it (like in Poland). So its very possible that there is something in the air. I should be checked by frequency spectrum analyser - don’t think that mikrotik will show you mess.
We are testing it indoor not outdoor and we are still facing problems with these new channels..
Have any one a chance to test these frequencies?
Do you have wide range card compatible ?
yes
microwaves and bluetooth devices are also indoor, make sure there really is no interference.
Hi normis:
We are testing inside the lab “only our mikrotik access point”
I need a user who already used and run these channels!!
