My results:
it is theoretically possible to have signal level of - 47 at 130km
it is theoretically possible to have signal level of - 48 at 145km
it is theoretically possible to have signal level of - 49 at 160Km
Transmit cable type : Times Microwave LMR-600
Transmit cable length : 1.640 feet (0.500 meters)
Total transmit cable loss : 0.119 dB (0.073 dB/foot 0.238 dB/meter)
Total transmit connector loss : 0.500 dB through 2 connectors
Total transmit cable loss : 0.619 dB
Transmit miscellaneous losses : 1.000 dB
Transmit antenna peak gain : 35 dBi
RF input power to the antenna : 25.381 dBm (345.223 milliwatts)
Allowed input power to antenna : 20.333 dBm (107.969 milliwatts) Per FCC Part 15 rules
Transmit antenna height : 2624.672 feet (800.000 meters)
Distance to the radio horizon : 70.300 miles (113.137 kilometers)
Receive cable type : Times Microwave LMR-400
Receive cable length : 1.640 feet (0.500 meters)
Total receive cable loss : 0.178 dB (0.108 dB/foot 0.355 dB/meter)
Total receive connector loss : 0.500 dB through 2 connectors
Total receive cable loss : 0.678 dB
Receive miscellaneous losses : 1.000 dB
Receive antenna peak gain : 35 dBi
Receive antenna height : 2624.672 feet (800.000 meters)
Received power level : -61.778 dBm (182.211 µV)
Receiver’s threshold : -82.000 dBm (17.762 µV)
Thermal fade margin : 20.222 dB Very good link.
Probability of outage : 0.1 %
Total free space path loss : 155.481 dBi over a path length of 151.615 miles (244.000 kilometers)
Peak transmitted EIRP : 59.381 dBm (867124.763 mW) This power output violates current FCC rules for point to multipoint links.
Midpoint 0.6 Fresnel zone boundary : 142.539 feet (43.446 meters)
Maximum space wave communications distance : 140.600 miles (226.274 kilometers)
What about your ack-timeout?
Are you able to made the link without nstreme (nstreme bypass the ack-timeout limitation that, if I’m not in wrong, is of 409us for Atheros 5213)?
to mipland: link is NOT possible without nstreme as it was continously connecting/disconnecting due to ack problem.
to matthias: we have rules here that allows us 2W eirp for p2mp links but they dont cover p2p links. We are trying to explain to prehistoric minds in our government that we are in export business now but they are having hard time understanding how we can export something that you cant touch.
macgiver: below is average ping times when there was approx 2mbits passing through the link.
100 packets transmitted, 100 packets received, 0% packet loss
round-trip min/avg/max = 5/10.2/35 ms
with this traffic TX/RX CCQ is almost always at 100/100
I must say that we were very skeptical of any link of this magnitude as well, but guess what, it works!
anyone in egypt want to shoot for a 500km link? naah
is very important for me. I had the same issues with a 112km link: succesfully connection for about 1-2 seconds, then disconnect, then succesfully connection for 1-2 sec. then disconnect and so on… and your answer is the confirms my doubt!
Thanks again
what is the thoughput you are getting on this link in terms of MB? I suggest if possible,try putting up an FTP server one side and ftp cleint on other side and transfer so big file so that you get the actual stats of througput
Has anybody of you tried setting up solar panels, wind generators or something similar to power those boards in remote places? we are looking into it since this is our main problem for links like these…power..
Lots more are to come given the weather and the timing is good
