I bought a RB450 and I want it to replace my wrt54g that is routing for my subnet.
It needs to login to pppoe and get a static ip (76.10.188.153)
it should route a /29 subnet (subnet mask: 255.255.255.248) from 76.10.189.153-159
I have read on these forums that these devices are a ‘router out of the box’, but I am having difficulty.
On the wrt54g I have it changed from ‘gateway’ mode to ‘routing’ mode. and RIPv1 and v2 turned on.
aside from that and setting the LAN ip address and entering pppoe info I did not have to do anything special.
I have pppoe client setup and connecting on ether1. it receives the correct IP from my isp.
I have ether2-5 in a bridge and I set the bridge’s IP address to my subnet gateway IP. (76.10.189.153)
I have been reading the wiki and searching for similar setups on the forum but I cannot find what makes the routing work on this device.
Please help!
