24v Power question for RB532
I know this has been discussed more than once, but I’m looking for the up-to-date answer. I have 24V at my tower site and I’ll be powering the RB532 with daughterboard directly with power port, NOT poe.
Which setting should the jumper be on since 24v seems to be at the transition point?
Scott
It should work if you set it to high power mode (25…56). using the low range can kill your device with a sudden spike.
