250Mpbs plan but I'm getting only 100Mbps
First of, I’m a complete newbie when it comes to this stuff. I recently changed to a new ISP plan that gives 250Mpbs speed, but I’m only getting 100Mbps on my computer. So far all I did was to test Mikrotiks public bandwidth and it was giving me around 200Mbps. I also got my config file, but I don’t know what info on there is private and I need to remove. Can someone eli5 this to me?
Edit: I ran bandwidth test tool in winbox and it gives me 340Mbps
Edit 2: I also checked something I’ve seen in another thread https://imgur.com/a/El7UrFZ. 3 out of 5 of these interfaces or whatever you call it have link rate at 100Mbps, other 2 are at 1Gbps
Edit 3: I found out how to export config without private info.
# may/01/2022 15:43:50 by RouterOS 6.48.5
# software id = KBW6-858X
# model = RBD52G-5HacD2HnD
# serial number = E5780E671B76
/caps-man channel
add band=2ghz-b/g/n extension-channel=XX name=channe24 reselect-interval=1d \
    save-selected=yes
add band=5ghz-a/n/ac extension-channel=XXXX name=channel50 reselect-interval=1d \
    save-selected=yes
add admin-mac=2C:C8:1B:67:2A:A1 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] advertise="10M-half,10M-full,100M-half,100M-ful\
    l,1000M-half,1000M-full,2500M-full,5000M-full,10000M-full"
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
    use-peer-dns=yes user=u178462
/interface wireless
# managed by CAPsMAN
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=\
    MikroTik-672AA5 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX \
    MikroTik-672AA6 wireless-protocol=802.11
/caps-man datapath
add bridge=bridge client-to-client-forwarding=yes local-forwarding=yes name=\
    datapath1
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm \
    name=security1
/caps-man configuration
add channel=channe24 datapath=datapath1 mode=ap name=cfg24 rx-chains=0,1,2 \
    security=security1 ssid=MomoKL tx-chains=0,1,2
add channel=channel50 datapath=datapath1 mode=ap name=cfg50 rx-chains=0,1,2 \
    security=security1 ssid=MomoKL5 tx-chains=0,1,2
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.10.100-192.168.10.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/caps-man aaa
set mac-mode=as-username-and-password
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=a,ac,an \
    master-configuration=cfg50 name-format=prefix-identity name-prefix=5G
add action=create-dynamic-enabled hw-supported-modes=b,g,gn \
    master-configuration=cfg24 name-format=prefix-identity name-prefix=2G
add bridge=bridge comment=defconf interface=wlan2
add comment=defconf interface=pppoe-out1 list=WAN
/interface wireless cap
set bridge=bridge discovery-interfaces=bridge,wlan1,wlan2 enabled=yes \
    interfaces=wlan1,wlan2
add address=192.168.10.1/24 comment=defconf interface=bridge network=\
    192.168.10.0
add address=192.168.0.1/24 interface=bridge network=192.168.0.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.10.11 client-id=1:4c:11:bf:7c:e8:35 mac-address=\
    4C:11:BF:7C:E8:35 server=defconf
add address=192.168.10.12 client-id=1:4c:11:bf:7c:e8:33 mac-address=\
    4C:11:BF:7C:E8:33 server=defconf
add address=192.168.10.20 client-id=1:bc:32:5f:af:99:ab mac-address=\
    BC:32:5F:AF:99:AB server=defconf
add address=192.168.10.23 client-id=1:6c:1c:71:68:7f:f8 mac-address=\
    6C:1C:71:68:7F:F8 server=defconf
add address=192.168.10.24 client-id=1:6c:1c:71:a3:9:db mac-address=\
    6C:1C:71:A3:09:DB server=defconf
add address=192.168.10.22 client-id=1:6c:1c:71:80:1:53 mac-address=\
    6C:1C:71:80:01:53 server=defconf
add address=192.168.10.29 client-id=1:6c:1c:71:a3:9:c7 mac-address=\
    6C:1C:71:A3:09:C7 server=defconf
add address=192.168.10.30 client-id=1:6c:1c:71:a3:9:e1 mac-address=\
    6C:1C:71:A3:09:E1 server=defconf
add address=192.168.10.28 client-id=1:6c:1c:71:a3:9:f1 mac-address=\
    6C:1C:71:A3:09:F1 server=defconf
add address=192.168.10.27 client-id=1:24:52:6a:1b:c9:de mac-address=\
    24:52:6A:1B:C9:DE server=defconf
add address=192.168.10.26 client-id=1:6c:1c:71:68:82:7e mac-address=\
    6C:1C:71:68:82:7E server=defconf
add address=192.168.10.25 client-id=1:6c:1c:71:68:7f:e9 mac-address=\
    6C:1C:71:68:7F:E9 server=defconf
add address=192.168.10.0/24 comment=defconf gateway=192.168.10.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf disabled=yes name=router.lan
add address=192.168.10.1 comment=defconf disabled=yes name=router.lan
    established,related,untracked
    invalid
add action=accept chain=input comment="defconf: accept WINBOX" dst-port=38291 \
    protocol=tcp
    "defconf: accept to local loopback (for CAPsMAN)" dst-address=192.168.10.1
    "defconf: accept to local loopback (for CAPsMAN)" dst-address=192.168.1.1
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface-list=WAN
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api port=38728
set winbox port=38291
set api-ssl port=38729
/system clock
set time-zone-name=Europe/Kiev
/system identity
set name=MikroTikIKK
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes
This is my model: RBD52G-5HacD2HnD
This is my firmware: RouterOS 6.48.5
Edit 4: turns out my ISP set me up with a wrong TP-Link switch, which was 10/100 Mbps
That will do it! Happy to see that you figured it out.
