261,1km link up and running!
Hy, I’m very pleased to announce that, with RouterOS and it’s essential “nstreme” function, today we have realized a 261,1km wifi (802.11a) shoot.
Board 1: Wrap (with ROS Level 4)
mPCI 1: Ubiquiti SR5
Ant 1: Pac Wireless 29dBi grid
Board 2: Wrap (with ROS Level 4)
mPCI 2: Ubiquiti SR5
Ant 2: Pac Wireless 29dBi grid
Signal received fluctuating between -76 and -88
Noise between -106 and -103
Freq.: 5765MHz@10MHz bandwidth
Real TCP bandwith (half) 6Mbps
CCQ between 40 and 60 (yes, i know, it’s not much, but we are working to improve it)
The link is rock solid.
Next time (i think on next two months) we will try a 307km@5765MHz shoot, but with more wider dishes.
If you have any questions, please post here.
P.S.
The word “we” stands for 13 people (4 plus me on one side, 8 on the other side) of an italian radioHAM association, it’s name is CISAR.
P.P.S.
Have you got some suggestion to improve the bandwidth of our link?
At the moment, we use nstreme with “none” framer policy.
We tryed 5Mhz: 2 to 3 Mbps TCP half
We tryed 10Mhz: 5 to 6 Mbps TCP half
We tryed 20Mhz: 7 to 8 Mbps TCP half
Thanks to all
73 de IZ3HAD
Congratulations!
Can you give us the UDP throughput (not using the WRAP boards to generate /receive the traffic). Two RB532s at 400MHz would probably increase the speed a bit also.
If you could write with the nstreme settings, we might be able to suggest something to try to increase the speed.
Good Work!
You can test turbo chanel with nstream,two 1ghz pc?
I will let you know. I can not do this test on today.
Yes, i know (and hope) it, but for the moment, the hardware is this two wrap. :wink:
I wrote it on the main post:
Sorry, I can’t do it soon. One site is at 1600m asl, not so easy to join it.
The second site is “only” 1200m asl, but we need to walk through a mountain path for about 30 minutes to join it.
Nice work and greetings from Croatian HAM operator!
73 de 9A3BSP!
Hi 9A3BSP, on the same day (19/05/2007) we made a (about) 200km shoot to Croatia on analog ATV!
If i’m not in wrong, the operator on your side was Mladen A3XZ, and it was near Pola, but, if you want, i can give you more info (i have to ask to my friend, becouse i was 261,1km from that site :wink: ).
did you use bandwidth tester from pc to router ( not from routerboard to routerboard )
results plz
skynoc
