2CC-5G CA, or NR CA found a modem that supports it
Hi MikroTik,
The Snapdragon X55 in the Chateau 5G does not support 2CC-5G CA or NR CA.
But the Fibocom FM350-GL: https://www.fibocom.com/en/products/5G-FM350-GL.html
Has the Mediatek M80 5G https://www.mediatek.com/technology/5g/5g-modem
Which is the basis of the Dimensity 700 which does support 2CC-5G CA.
Before I go and purchase the m.2 modem: https://www.aliexpress.com/item/1005004444946323.html
Can you advise what you would require to support this modem which is twice the capability of your current Quectel offering?
Got the FM350, it happily turns up on Ubuntu 22.10.
Correctly registered, driver etc all working.
Nothing on RouterOS7 though :frowning:
Correct me if Im wrong, but FM350 has only pcie interface, no USB interface.
Probably impossible to run on any MT board.
Why on earth would you use USB instead of PCIe ?
