Hello:
I’ve 2 internet connections, one Cable (4Mbps/512Kbps) and another ADSL (1Mbps/512Kbps, but with dynamic IP).
Can I do these configuration
-use 512K/512K of the cable for Server1
-use the ADSL for NAT and add only the download speed (3.5Mbps) of the Cable, not using the cable upload?
Resize a connection (4096/512Kbps) to a 512Kbps/512Kbps for a server in the network, and use the residuary (download speed) to add this bandwidth to the ADSL connection??
Is more clear my question??
OK, thanks.
Another question, what type of load balancing is better for my network, because before I’ve a Hotbrick Router loadbalacing, but I’ve a lot of problems with downloading, Messenger disconnections and problems like these.
