in firewall mangal the rule
action=accept chain=prerouting comment=“” disabled=no dst-address=192.168.2.0/24 in-interface=Local
dont count (dont work)
/ip firewall mangle
add action=mark-connection chain=input comment=“” disabled=no in-interface=wlan1 new-connection-mark=wlan1_conn passthrough=yes
add action=mark-connection chain=input comment=“” disabled=no in-interface=wlan2 new-connection-mark=wlan2_conn passthrough=yes
add action=mark-routing chain=output comment=“” connection-mark=wlan1_conn disabled=no new-routing-mark=to_wlan1 passthrough=yes
add action=mark-routing chain=output comment=“” connection-mark=wlan2_conn disabled=no new-routing-mark=to_wlan2 passthrough=yes
add action=accept chain=prerouting comment=“” disabled=no dst-address=192.168.2.0/24 in-interface=Local
add action=accept chain=prerouting comment=“” disabled=no dst-address=192.168.1.0/24 in-interface=Local
add action=mark-connection chain=prerouting comment=“” disabled=no dst-address-type=!local in-interface=Local new-connection-mark=wlan1_conn passthrough=yes
per-connection-classifier=both-addresses-and-ports:2/0
add action=mark-connection chain=prerouting comment=“” disabled=no dst-address-type=!local in-interface=Local new-connection-mark=wlan2_conn passthrough=yes
per-connection-classifier=both-addresses-and-ports:2/1
add action=mark-routing chain=prerouting comment=“” connection-mark=wlan1_conn disabled=no in-interface=Local new-routing-mark=to_wlan1 passthrough=yes
add action=mark-routing chain=prerouting comment=“” connection-mark=wlan2_conn disabled=no in-interface=Local new-routing-mark=to_wlan2 passthrough=yes
add action=dst-nat chain=dstnat comment=“” disabled=yes dst-port=80 protocol=tcp src-address=10.10.10.0/24 to-addresses=192.168.1.55 to-ports=3128
add action=masquerade chain=srcnat comment=“” disabled=no out-interface=wlan1
add action=masquerade chain=srcnat comment=“” disabled=no out-interface=wlan2
add check-gateway=ping comment=“” disabled=no distance=2 dst-address=0.0.0.0/0 gateway=192.168.2.2 scope=30 target-scope=10
add check-gateway=ping comment=“” disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.1.1 scope=30 target-scope=10
add check-gateway=ping comment=“” disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.2 routing-mark=to_wlan2 scope=30 target-scope=10
add check-gateway=ping comment=“” disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=to_wlan1 scope=30 target-scope=10
add address=192.168.1.249/24 broadcast=192.168.1.255 comment=“” disabled=no interface=wlan1 network=192.168.1.0
add address=10.10.10.1/24 broadcast=10.10.10.255 comment=“” disabled=no interface=Local network=10.10.10.0
add address=192.168.2.249/24 broadcast=192.168.2.255 comment=“” disabled=no interface=wlan2 network=192.168.2.0
