2km link clear view i need your suggestions
hi
i wanna link 2 km link with clear view
using RBLHG-60AD
does it enough with 350mgbs download stable?
or i should change the device,
You will geht Full Speed with Perfect allignment
But you will loose Connection with every rain
Well 2km is a little too much…the max is about 1.5 km
@mistry7 why you say the connection will be so bad in rainy conditions ?
so what should i chose ? do you have recommendation ?
We have several links at this distance, we are rain area g, depends on region he will loose connection on every rain.
Most times only couple of seconds but the connection drops.
Would it be a Problem to lose Connection for some seconds when it rains? If not, LHG60G is Good option
RBSXTsqG-5acD
Assuming you just want a point to point link.
350 MBit stable with SXTsq over 2km? Goog luck
Sad to say but for 2 km link i s better to use airfiber 5hd form ubiquiti
:open_mouth:
