I would like to create a point-to-point wireless link (5 GHz) between two buildings.
The distance to cover is about 2 Km.
The system will have to sustain throughput of around 24 Mbps (the theoretical speed of ADSL2+).
Which Mikrotik components do you suggest me to use?
Regards.
