2km link
hi
over 2.5 years i have link 2KM, and i get 100mbps with no problems,
before couple days someone build a new house in 10 meters from one of antennas(witch is about 50-100cm higher from antenna) , and now i have problems, i get only ~ -72 signal
i have:rb411+r52HN +cyberbajt gigaeter 19dbi antenna.
i cant go high, and if i change these 19dbi to grid 27dbi can i get real 100mbps ore what to i do?
i need to have 100/100 mbps.
What for frequency use you?
Have you perfect line of sight?
Give us more details about that
hi,
freq=5200 mhz because in these only work better, and line of sight is not perfect.. but before tht new house in front of one AP i had -63 nad more than 100mbps, now is -73
Try this with 2 19Db antennas.
If that failed try the grid but it is not garanted that the link is stable without los
You have two problems LOS and Freznel zone and no antenna selection is going to fix, the best solution it to move one or both antenna(s) and get LOS and clear freznel zone
