2Km PtP
Hey every body
I wanna start a wireless connection with MikTik device, yet there are problems:
First two radio with 2Km distant and 1Gb bandwidth on 5Ghz under Layer 2 connection.
Now the problem is:
with 1Gb I can only use half of bandwidth and the fact is I heard about Nv2 and MPLS but I don’t know which one is better or if there is any other solution!
in the end if I can reach 900 Mbps or near it would be enough
regards
