Hi, so i have ether1 as a wan(1 pppoe account) with dinamyc ip and ether2 as another wan with 2 pppoe accounts(same wire, just 2 pppoe accounts) each one with a static ip, my goal is that a computer connected to ether4 to be on the ether1 internet connection and another one to ether5 on the ether2 internet connection in the same time, no load balancing.. i’m kind a lost here
Use routing marks in mangle, and after that apply the routing marks in routing table
/ip firewall mangle
add chain=prerouting src-address=computer1 action=mark-connection new-connection-mark=comp1
add chain=prerouting connection-mark=comp1 action=mark-routing new-routing-mark=comp1
same should be done for the other PC. Then:
add dst-address=0.0.0.0/0 gateway=pppoe1 routing-mark=comp1
add dst-address=0.0.0.0/0 gateway=pppoe2 routing-mark=comp2
Thank you, i’ll try this and come back with feedback
Ok, at the moment of enabling those rules i can’t ping/reach my internal network/hosts 192.168.10.0/24 from my vpn-pptp connection 192.168.30.0/24 network, why is that?
That’s because with policy routing in place, when network 192.168.10.0/24 tries to reach 192.168.30.0/24 instead of using the default connected route, it will go through the gateway into the internet. To avoid that, in mangle you should place a rule before the ones needed for policy routing:
/ip firewall mangle
add chain=prerouting src-address=192.168.10.0/24 dst-address=192.168.30.0/24 action=accept
add chain=prerouting src-address=192.168.30.0/24 dst-address=192.168.10.0/24 action=accept
Ok thank you again, i’ve made a test but there is no internet connection on my laptop, maybe is something wrong with my routes?
routes
0 A S dst-address=0.0.0.0/0 gateway=rds_acc50_229
gateway-status=rds_acc50_229 reachable distance=1 scope=30
target-scope=10 routing-mark=laptop
1 ADS dst-address=0.0.0.0/0 gateway=10.0.0.1
gateway-status=10.0.0.1 reachable via rds_acc50_229 distance=1
scope=30 target-scope=10
2 ADC dst-address=10.0.0.1/32 pref-src=5.14.22.112
gateway=rds_fb100,rds_acc50_228,rds_acc50_229
gateway-status=rds_fb100 reachable,rds_acc50_228 reachable,rds_acc50_229
reachable
distance=0 scope=10
mangle
0 chain=prerouting action=accept src-address=192.168.10.0/24
dst-address=192.168.30.0/24 log=no log-prefix=""
1 chain=prerouting action=accept src-address=192.168.30.0/24
dst-address=192.168.10.0/24 log=no log-prefix=""
2 chain=prerouting action=mark-connection new-connection-mark=laptop
passthrough=yes src-address=192.168.10.0/24 log=no log-prefix=""
3 chain=prerouting action=mark-routing new-routing-mark=laptop
passthrough=yes connection-mark=laptop log=no log-prefix=""
rds_fb_100 is the dinamic pppoe connection and rds_acc50_229&228 are the pppoe connections with a static ip
On the mangle rules, change the last one passthrough=no
/ip firewall mangle
chain=prerouting action=mark-routing new-routing-mark=laptop passthrough=no connection-mark=laptop
that means that packets will not be processed any more and the mark will remain.
Thank you again, i have made a test an still the same problem no internet connection, maybe i’m doing something wrong?
What about the masquerade rule? How is it set?
Try with a simple masquerade:
add chain=srcnat action=masquerade
Well here are the rules
chain=srcnat action=masquerade out-interface=rds_fb100 log=no
log-prefix=""
chain=srcnat action=masquerade out-interface=rds_acc50_228 log=no
log-prefix=""
chain=srcnat action=masquerade out-interface=rds_acc50_229 log=no
log-prefix=""
It should work, I don’t see anything stopping it from working.
Try it again, try it with pinging from laptop. Are you using dhcp-server? If yes what is the lease to the laptop, ip address, gateway, dns server?
If not, post in here /ip firewall, /ip route, /ip addresses to have the whole picture in one place.
Yes i’m using dhcp-server, my config is ether1 and ether2 as wans, ether3 master with dhcp server(192.168.10.0/24 network) on it for ether4 and ether5(slaves for ether3). My laptop is on ether5 with static ip 192.168.10.100
On ether2 i have 2 pppoe accounts each one with a different static ip
[admin@MikroTik] > ip firewall filter print detail
0 X ;;; place hotspot rules here
chain=unused-hs-chain action=passthrough log=no log-prefix=""
1 ;;; default configuration
chain=input action=accept protocol=icmp log=no log-prefix=""
2 ;;; default configuration
chain=input action=accept connection-state=established log=no
log-prefix=""
3 ;;; default configuration
chain=input action=accept connection-state=related log=no log-prefix=""
4 chain=input action=accept protocol=udp in-interface=ether1_WAN_rds_fb100
src-port=67,68 dst-port=67,68 log=no log-prefix=""
5 ;;; default configuration
chain=input action=jump jump-target=log and drop
in-interface=ether1_WAN_rds_fb100 log=no log-prefix=""
6 ;;; default configuration
chain=forward action=accept connection-state=established log=no
log-prefix=""
7 ;;; default configuration
chain=forward action=accept connection-state=related log=no
log-prefix=""
8 ;;; default configuration
chain=forward action=drop connection-state=invalid log=no log-prefix=""
9 chain=input action=jump jump-target=log and drop protocol=tcp
in-interface=rds_fb100 dst-port=22 log=no log-prefix=""
10 chain=input action=jump jump-target=log and drop protocol=tcp
in-interface=rds_acc50_228 dst-port=22 log=no log-prefix=""
11 chain=input action=jump jump-target=log and drop protocol=tcp
in-interface=rds_acc50_229 dst-port=22 log=no log-prefix=""
12 chain=input action=jump jump-target=log and drop protocol=tcp
in-interface=rds_fb100 dst-port=23 log=no log-prefix=""
13 chain=input action=jump jump-target=log and drop protocol=tcp
in-interface=rds_acc50_228 dst-port=23 log=no log-prefix=""
14 chain=input action=jump jump-target=log and drop protocol=tcp
in-interface=rds_acc50_229 dst-port=23 log=no log-prefix=""
15 X chain=input action=jump jump-target=log and drop protocol=tcp
in-interface=rds_fb100 dst-port=21 log=no log-prefix=""
16 X chain=input action=jump jump-target=log and drop protocol=tcp
in-interface=rds_fb100 dst-port=80 log=no log-prefix=""
17 chain=input action=drop protocol=udp in-interface=rds_fb100 dst-port=53
18 chain=input action=drop protocol=udp in-interface=rds_acc50_228
dst-port=53 log=no log-prefix=""
19 chain=input action=drop protocol=udp in-interface=rds_acc50_229
20 chain=input action=jump jump-target=log and drop protocol=tcp
in-interface=rds_fb100 dst-port=53 log=no log-prefix=""
21 chain=input action=jump jump-target=log and drop protocol=tcp
in-interface=rds_acc50_228 dst-port=53 log=no log-prefix=""
22 chain=input action=jump jump-target=log and drop protocol=tcp
in-interface=rds_acc50_229 dst-port=53 log=no log-prefix=""
23 I ;;; ppp-out1 not ready
in-interface=ppp-out1 dst-port=22 log=no log-prefix=""
24 I ;;; ppp-out1 not ready
in-interface=ppp-out1 dst-port=23 log=no log-prefix=""
25 I ;;; ppp-out1 not ready
in-interface=ppp-out1 dst-port=21 log=no log-prefix=""
26 I ;;; ppp-out1 not ready
in-interface=ppp-out1 dst-port=80 log=no log-prefix=""
27 chain=log and drop action=log log=no log-prefix=""
28 chain=log and drop action=drop log=no log-prefix=""
29 chain=input action=accept protocol=udp src-address-list=L2TP_Allowed
dst-port=1701 log=no log-prefix=""
30 chain=input action=accept protocol=udp dst-port=500,4500 log=no
log-prefix=""
31 chain=forward action=jump jump-target=log and drop
src-address=192.168.60.96/27 dst-address=192.168.10.96/27 log=no
log-prefix=""
32 X chain=input action=jump jump-target=log and drop dst-address=192.168.10.1
in-interface=wlan3 log=no log-prefix=""
33 X chain=input action=accept protocol=tcp dst-port=21 log=no log-prefix=""
[admin@MikroTik] > ip firewall nat print detail
1 X ;;; default configuration
chain=srcnat action=masquerade out-interface=et
2 chain=srcnat action=masquerade out-interface=rd
log-prefix=""
chain=srcnat action=masquerade out-interface=pp
log-prefix=""
4 X chain=dstnat action=dst-nat to-addresses=192.16
protocol=tcp dst-port=53 log=no log-prefix=""
5 X chain=dstnat action=dst-nat to-addresses=192.16
protocol=udp dst-port=53 log=no log-prefix=""
6 chain=srcnat action=masquerade out-interface=et
log-prefix=""
7 chain=dstnat action=dst-nat to-addresses=192.168.10.106 to-ports=21
protocol=tcp dst-address=5.14.xx.xx dst-port=21 log=no log-prefix=""
8 chain=srcnat action=masquerade out-interface=rds_acc50_228 log=no
log-prefix=""
9 chain=srcnat action=masquerade out-interface=rds_acc50_229 log=no
log-prefix=""
10 chain=srcnat action=masquerade log=no log-prefix=""
[admin@MikroTik] > ip firewall mangle print detail
passthrough=no connection-mark=laptop log=no log-prefix=""
[admin@MikroTik] > ip route print detail
gateway-status=10.0.0.1 reachable via rds_fb100 distance=1 scope=30
target-scope=10
2 ADC dst-address=10.0.0.1/32 pref-src=86.122.xx.xx
gateway=rds_acc50_229,rds_acc50_228,rds_fb100
gateway-status=rds_acc50_229 reachable,rds_acc50_228 reachable,
rds_fb100 reachable
distance=0 scope=10
3 S dst-address=192.168.1.0/24 gateway=192.168.40.200
gateway-status=192.168.40.200 unreachable distance=1 scope=30
target-scope=10
4 A S dst-address=192.168.2.1/32 gateway=wlan1 gateway-status=wlan1 reachable
check-gateway=ping distance=1 scope=30 target-scope=10
5 ADC dst-address=192.168.10.0/24 pref-src=192.168.10.1
gateway=ether3_MASTER_4_5 gateway-status=ether3_MASTER_4_5 reachable
distance=0 scope=10
6 ADC dst-address=192.168.20.0/24 pref-src=192.168.20.1 gateway=wlan1
gateway-status=wlan1 reachable distance=0 scope=10
7 DC dst-address=192.168.40.0/24 pref-src=192.168.40.1
gateway=ether6_MASTER_7_8_10
gateway-status=ether6_MASTER_7_8_10 unreachable distance=255 scope=10
8 ADC dst-address=192.168.50.0/24 pref-src=192.168.50.1 gateway=wlan2
gateway-status=wlan2 reachable distance=0 scope=10
[admin@MikroTik] > ip address print detail
0 X ;;; default configuration
address=192.168.88.1/24 network=192.168.88.0 interface=wlan1
actual-interface=wlan1
1 address=192.168.10.1/24 network=192.168.10.0 interface=ether3_MASTER_4_5
actual-interface=ether3_MASTER_4_5
2 address=192.168.20.1/24 network=192.168.20.0 interface=wlan1
3 address=192.168.40.1/24 network=192.168.40.0 interface=ether6_MASTER_7_8_1>
actual-interface=ether6_MASTER_7_8_10
4 address=192.168.50.1/24 network=192.168.50.0 interface=wlan2
actual-interface=wlan2
5 I address=192.168.60.97/27 network=192.168.60.96 interface=wlan3
actual-interface=wlan3
6 X address=86.122.xx.xx/32 network=86.122.xx.x interface=ether2_WAN_rds_acc5>
actual-interface=ether2_WAN_rds_acc50
7 X address=86.122.xx.xx/32 network=86.122.xx.x interface=ether2_WAN_rds_acc5>
8 D address=86.122.xx.xx/32 network=10.0.0.1 interface=rds_acc50_229
actual-interface=rds_acc50_229
9 D address=86.122.xx.xx/32 network=10.0.0.1 interface=rds_acc50_228
actual-interface=rds_acc50_228
10 D address=5.14.xx.xx/32 network=10.0.0.1 interface=rds_fb100
actual-interface=rds_fb100
[admin@MikroTik] > interface pppoe-client print detail
0 R name="rds_acc50_228" max-mtu=1480 max-mru=1480 mrru=1
interface=ether2_WAN_rds_acc50 user="xx"
password="xx" profile=default keepalive-timeo
service-name="" ac-name="" add-default-route=no dial-
use-peer-dns=yes allow=pap,chap,mschap1,mschap2
1 R name="rds_acc50_229" max-mtu=1480 max-mru=1480 mrru=1
2 R name="rds_fb100" max-mtu=1480 max-mru=1480 mrru=disab
interface=ether1_WAN_rds_fb100 user="xx" p
profile=default keepalive-timeout=60 service-name=""
add-default-route=yes default-route-distance=1 dial-o
192.168.30.0/24 is the pptp-vpn network
I am a bit baffled why this is not working. Let’s try a different approach. Keep all the config that is needed for this one to work, i.e the mangle rules stay, leave only the masquerade rule in /ip firewall nat, and then disable all rest in nat and in /ip firewall filter and see if it works or not.
Ok so i have checked over and over again, disabled rules nat etc still the same thing.. i cleaned my config a bit here is the result
0 ;;; default configuration - icmp
1 ;;; default configuration - established
log-prefix=""
2 ;;; default configuration - related
3 ;;; default configuration - established
log-prefix=""
4 ;;; default configuration - related
chain=forward action=accept connection-state=related log=no log-prefix=""
6 chain=log and drop action=log log=no log-prefix=""
7 chain=log and drop action=drop log=no log-prefix=""
0 chain=srcnat action=masquerade out-interface=rds_fb100 log=no
log-prefix=""
1 chain=srcnat action=masquerade out-interface=rds_acc50_228 log=no
log-prefix=""
2 chain=srcnat action=masquerade out-interface=rds_acc50_229 log=no
log-prefix=""
0 address=192.168.10.1/24 network=192.168.10.0 interface=ether3_MASTER_4_5
1 D address=86.122.xx.xx/32 network=10.0.0.1 interface=rds_acc50_228
2 D address=86.122.yy.yy/32 network=10.0.0.1 interface=rds_acc50_229
3 D address=5.14.zz.zz/32 network=10.0.0.1 interface=rds_fb100
gateway-status=rds_acc50_229 reachable distance=2 scope=30
target-scope=10
gateway=rds_acc50_228,rds_acc50_229,rds_fb100
gateway-status=rds_acc50_228 reachable,rds_acc50_229 reachable,
rds_fb100 reachable
distance=0 scope=10
3 ADC dst-address=192.168.10.0/24 pref-src=192.168.10.1
distance=0 scope=10
0 R name="rds_acc50_228" max-mtu=1480 max-mru=1480 mrru=1600
interface=ether2_WAN_rds_acc50 user="*"
password="*" profile=default keepalive-timeout=60
service-name="" ac-name="" add-default-route=no dial-on-demand=no
use-peer-dns=no allow=pap,chap,mschap1,mschap2
1 R name="rds_acc50_229" max-mtu=1480 max-mru=1480 mrru=1600
2 R name="rds_fb100" max-mtu=1480 max-mru=1480 mrru=disabled
interface=ether1_WAN_rds_fb100 user="*" password="*"
profile=default keepalive-timeout=60 service-name="" ac-name=""
add-default-route=yes default-route-distance=1 dial-on-demand=no
[admin@MikroTik] > ip dhcp-server print detail
0 name="dhcp_lan" interface=ether3_MASTER_4_5 lease-time=3d
address-pool=dhcp_lan_pool bootp-support=static
authoritative=after-2sec-delay lease-script=""
Anyway disabling this rule restores internet connection but not the marked one(in my case _229). Instead the _fb100 is used
Well, the idea is simple. One marks the traffic by means of mangle and then routes that traffic to the desired gateway in ip routes.
Either that gateway is not working, or dns settings on laptop are not correct (not able to resolve http).
How can i debug further? All my laptop settings are ok, static ip 192.168.10.100, google dns 8.8.8.8 and 8.8.4.4.. is not a problem from here since neither ping isn;t working outside
Pinging 8.8.8.8 with 32 bytes of data:
Request timed out.
Request timed out.
What do you mean by gateway not working?
Any help on this please? Or maybe a paid one since i really need this
