2VLANs on RB2011 and other routers for guest and office access
Hi all,
I want to use an RB2011 to allow wired and wireless office access with wireless-only access for guests daisychained. The RB2011 will connect to the internet and office LAN. It should provide wireless office access as well as wireless guest access on separate VLANs and SSIDs. It should trunk those VLANS to routers down the line. Each router down the line only has to provide wireless guest access until the last one which should provide wired and wireless access.
Can anyone help with this please? What are the cheapest routers that I can use for R2, R3 & R4?
Thanks for reading.
NTB
8o)
You can do this with all MikroTik routers and APs.
Of course you have to do some study because it will not come preconfigured like that.
Thanks for the reply. I was looking for a bit guidance on how to get the wireless sections on the VLANs
A few threads:
http://forum.mikrotik.com/t/configure-vap-with-multiple-vlan/61538/1
http://forum.mikrotik.com/t/solved-vlans-virtual-ap-and-hotspot-on-bridged-interface/79030/1
