Hi. I got a problem that I tried twice to resolve and always ended up with restoring to factory defaults ;(
I have a router provided by the provider and then hooked up 8 port switch which then has cables run across the house. In 2 rooms I have cAP ac wired to get signal boosted. I was surprised with the performance so I even disabled router WiFi.
Now, I wanted always to get to the point that cAPs are like ‘antennae’ for the router, not routers themselves. This is because being on 1 network I don’t have access to the printer on the other cAP network. Also, I would like all devices connected to both cAPs to see each other. Both cAPs have the same WiFi names to create better (I think) switch in between.
When I set to bridge, then I can’t access cAP anymore by IP from the laptop connected to it. Only via Android app. In general, number of options and config variations is a bit overwhelming even in QickSet. I would get rid of them to buy something simpler but I am impressed with the performance, so I still want to give it a go.
Is anyone able to provide to me some guidance on how to set those as APs in a way that it is the same network and routing, dhcp etc. is done by router, please?
