Hi everyone,
which is the best way to balance traffic with two access point on each side (about 500m, each AP has two antennas) configured in nstreme dual?
This is the actual configuration (every device has RouterOS ver 3.9)
- each AP is configured in nstream dual
- I’ve created two EoIP tunnel (eth1a ↔ eth2c // eth1b ↔ eth2d)
- the two EoIP tunnels are configurated in bonding with balance rr
- there is a bridge between ETHLAN and the bonding interface on each router
Everything works, but i notice that the speed of two EoIP tunnel is the same than one EoIP tunnel (tried to disconnect one AP).
I tried to recreate the same setup locally (with ethernet cables instead of wireless) and I have the same behaviour with EoIP tunnels bonded (about 86Mb/s). Bonding ethernet interface directly (locally of course), without EoIP tunnels, works fine instead (about 180Mb/s).
Any suggestion?
Thanks in advance
