Guys,
Good Morning!
I need help.
I have the following scenario on a client.
Today I interconnect the company’s headquarters and branch through openvpn VPN (Headquarters = Server and Branch = Client).
Now I also need to configure via OVPN to VPN for employees in homeoffice.
first would this be possible?
Because looking at the settings of the RB750Gr3 I only saw the option to activate a single ovpn server.
Today the matrix x Branch configuration uses port 1194 and I wanted to create access for collaborators on port 1195.
Is there this possibility to create in Mikrotik?
Thanks!
If I understand what you are saying you have the following arrangement:
- Headquarters has an OpenVPN server configured.
- Branch Office has an OpenVPN client service connecting to the Headquarters OpenVPN server.
- There are staff working from home that need to connect via OpenVPN.
Do you want the staff to connect Headquarters OpenVPN server? If yes, why do you want to use a different port?
The OpenVPN server can handle multiple client connections so you would then only need to create the necessary users (and, I would suggest for security, client specific certificates for their OpenVPN configurations) and apply suitable rules to those accounts.
