Hi there,
I’m considering load balancing a few lines that we have to use with our hotspot system. But I would like to know if anyone can see any issues that may occur because of it. For example by having two routers (each doing a job) will load balancing work? Will data be chopped causing issues to the users or with things like VoIP.
RB-A) RB450G - Load balance 4x ADSL lines; 1 port to hotspot router
RB-B) RB450G - hotspot unit
Wired so that: RB-A → RB-B → User
The IP addressing of one ISP line should be passed to the RB-B unit.
Nope, works fine for me. Actually does all of this on one RB100, including Hotspot, but wanted to get a clear picture of exact bandwidth use on 4 ADSL, PCC load balance. Have also got a 4 ADSL bonded line selution on same router. Moved 4 ADSL PCC configuration onto RB450 and route traffic from RB1100 to RB450. Is running very nice. Pings is actually a bit better on PCC, still want to have a look and find why.
The first two rules capture users in my uncap address list and route them to the RB450. All the rest of the users is routed to the default route which is a bonded Cisco router with 4 ADSL’s. The next rules is a classic PCC setup, as described in the WIKI, doing the 4 ADSL load balancing. If you import them like this, they are disabled at this time because the exact code is on the RB450 which is doing the balancing at this time. In order for every thing to work on RB1100, i would disable first to roules and enable rest of the roules. Of cause the PPPoE connection is also made from the RB1100 to the ADSL’s at that time and also you have to set up routes in ip-routes for the routing marks in the mangle rules
