What’s new in 3.0rc1:
*) enable routing package on upgrade - to fix upgrade from 2.9 version
where routing-test package was used;
*) console - parser now accepts newlines as CR, LF, CR+LF, this fixes import;
*) user manager - using +/- image for group field show/hide instead of
confusing checkbox;
*) fixed bug - usb devices did not work;
*) console - added tab key completions in editor;
*) fixed slowness of RB112/RB133C during bootup (introduced in 3.0beta9);
*) console - fixed variable name lookup;
*) console - added back ‘/setup’ command;
*) console - added ‘/system script environment’;
*) console - fixed wireless interface configuration export;
*) integrated MAC Ping in to regular Ping in WinBox;
*) added support for Marvell IDE controller that is embeded in new Intel motherboards;
*) fixed bug - for routes received via RIP nexthop was invalid in some cases;
*) added ‘get’ tool for downloading files to router via HTTP or FTP;
*) console - some properties could not be set via API, fixed;
*) user manager - fixed bug for PayPal payments with user data containing
specific characters;
*) ip proxy - setting parent proxy did not work;
*) fixed bug - dst-active was not updated after time update by NTP;
*) console:
fixed ‘do’ arguments in ‘/tool bandwidth-test’ and other
commands;
inside expressions variables can be referenced without putting
‘$’ before variable name;
‘find’ commands have new argument ‘where’ that allows to write
filtering condition as console expression;
when entering commands from prompt, global variables can be used without
declaring them;
on 532A works fine… but i have bug with winbox.when system clock is opened first time, i cant change anything.after doing /system clock print in console and reopenning system clock in winbox all works fine
