3.0beta10 bug
After I upgrade my router from 2.9.44 to 3.0beta10:
Tourch not working - say “not enough permissions (9)” I have full permissions
And some scripts also no working say what there are some syntax errors, before upgrade all scripts was working fine.
there are new variable system in v3.0, most of old scripts won’t work.
there is new option in /user group
called sniff, add this to your group and relogin into router, that way you will have correct rights to use torch and other tools
this occurs if you upgrade from beta to newest beta10, id upgrade from 2.9.xx everything should be fine.
Thnks, janisk!
Before I see You post I did it and Torch started working :slight_smile:
Is there a newer/second version of beta10?
My APC UPS stopped to work with beta10
What where can be for problems?
