I install RouterOS 3.0 beta 10 with rb 133 but not work.
Later I install sepatared package 3.0beta10 but rb 133 not work too.
Later too I install two package the 3.0beta10: system + wireless but … the rb133 not work too .
And I install only system package on RB133 and miracle: the rb works fine.
installed b10 on customer nat router, specificlly to fix issue with SIP connections, SIP helper appears to help!
Can’t torch
in simple queue, lost all bandwidth counts, and current traffic (i know it was delayed)
also, in traffic view, packets keep going up and up and up and up, until you close and reopen the queue box.
To fix the torch issue you need to add the sniff flag to your user account..
You have to add the columns you’d like to display in the queue listing. You can use the little down arrow to the right of the queue window to add/remove columns from the view.
