3.0rc6 on 112 board (((
Hi every one
I have upgrated 2.9.45 to 3.0rc6 and having a lot of problems
It is working very bad CPU is 100% almost always
Scanning the wireless it shows just 2-3 AP-s, But with 2.9.45 They were ~30,
When testing Banthwith it crashes,
I don’t know what to do I need 3.0rc in order to disconnect wireless clients via radius
Please Help
With Regards
Karo Aznavuryan
Wireless, i can’t confirm but that with the bandwidth test i saw it on mine too, and it’s killing me. The board is rebooting after 2-5 sec’s on the btest.
I put 2.9.43 on them back.
Not much help, but I have had numerous problems with 3.x on 112 boards. Not problems any others. I just stop using them and used 532 instead with no problems.
Erik
I am seeing the same thing on a new 333 with 3.0rc4.
At first I thought it was just bandwidth tests to the 333 with 3.0rc4 but after testing I also saw testing from the 333 to a 133 with 2.9.38.
Hi, I found there is an “issue” with these versions as well. Try the latest version 3.0rc10. It fixed the wierdness for me.
I also found some spookiness with certain OS versions and 133 boards.
j.
I upgraded to rc10 and still notice the reboot while performing bandwdith tests. Here is my setup
333 rc10 ap bridge
133 2.9.38 wds bridge
wds mode: dynamic
bridging ethernet and wlan
wpa2 psk aes ccm
Could it be a watchdog rebooting the system?
Have you upgraded firmware also after software upgrade? /sys/rou/upg
How far is the POE if any, I noticed more that 30m is a no-no, sometimes more, sometimes much less depending on site.
Ekkas
