I noticed in the changelog in 3.1 support was added for Nvidia’s nForce ethernet chips.
Does anyone know which ones are supported?
I have 3.1 installed on a machine with a nForce 2 MCP chipset and the it didn’t work.
I have included a portion of my output from the ‘/system resource pci print detail’ command:
13 device="00:08.0" name="MCP2A PCI Bridge (rev: 163)" vendor="nVidia Corporation"
category="PCI bridge" vendor-id="0x10de" device-id="0x008b" irq=0
14 device="00:04.0" name="MCP2A Ethernet Controller (rev: 163)" vendor="nVidia Corporation"
category="Bridge" vendor-id="0x10de" device-id="0x008c" irq=9 memory=0xE0003000-0xE0003FFF
io=0xE000-0xE007
Perhaps only the newer nForce ethernet is supported, nForce 3 & nForce 4, etc..
