Do you think it will be possible in the future to allow MLPPP with L2TP / PPTP as well ? I see in the newsletter it will be supported for PPPoE for now. Great job guys, thanks!
Thx,
Sam
Thx,
Sam
A huge ‘great job’ coming from me too… It has arrived just in time as I am needing it for a setup I’m building.
Newsletter says it is only supported in PPPoE client, does this mean I cannot use MLPPP with the MT PPPoE Server?
where is the newsletter ?
in the mail
Unfortunately the link is to number 9, not the latest number 10. What happened to the subscription sign-up for the newsletters?
George
refresh!!!
Much better. Any idea where the sign-up link is now?
never was any. it just goes to your mikrotik.com account server email. if you unsubscribed at some point, just email to support with your login name
Dear All
it is here the mlppp at last.
how do l activate it?
l went to the interface and add the dsl (bridge mode)interfaces to the pppoe-client but still show only one link up.
Any help
thanks
Getting ready to test with ATT here shortly.
I still question if MLPPP is supported by PPPoE servers as well… or do we need to replace our MT-based PPPoE servers with some other flavour to get ML-PPPoE?
let’s first see how the client performs, ok ?
aah the cryptic answers no problem, was just checking
Dear All
Any help
thanks
Now you can specify more than one interface in pppoe-client. No bridges needed!
Wow, well very cool! I just tested MLPPP on 3.10, and by golly it works!
Since RouterOS doesn’t yet have MLPPP support in the PPPoE server, I set up a Cisco 2620 running IOS 12.3(17a) (C2600-TELCO-M) in order to test with, and configured three VLANs on it with PPPoE servers running on all of them and with multilink enabled. RouterOS 3.10 running on an RB333 established three sessions across each of the VLANs and both sides successfully multilinked them!
It’s not perfect yet, but I’m impressed! That was fast progress!
There are a few warts/bugs with RouterOS’s MLPPP, as is to be expected. It establishes the connections just fine, but it doesn’t seem to yet elegantly deal with interruptions to any of the individual sessions. Sometimes it works, sometimes it takes a while for it to adjust, and sometimes it never recovers (I managed at one point to crash the entire PPP client system…I couldn’t make it establish a PPPoE connection until after a reboot, multilinked or not! Don’t worry, I made a SUPOUT!).
I will put together a more formal test suite over the next few days and open tickets with MikroTik Support as necessary to get the bugs ironed out.
Thanks, MikroTik! Now, moving on to MLPPP support in RouterOS’s PPPoE server…
– Nathan
EDIT: Oh, I forgot to mention…at first I thought it didn’t work, but then I tried it again and discovered that it did: if you are not connecting to a MLPPP server, you can still use the multiple interfaces feature of the PPPoE client as a failover system! RouterOS will establish a PPPoE connection to the first one in the list, and then if that connection dies, it will re-connect over the second interface, and so on! Very cool.
thanks for the report! that will help us a lot
Dear all
l have 3 dsl and have add all the Ethernet interfaces to the pppoe-client but can’t still have the the three line up.
only one is active.
Any information will help.
the lsp is using juniter dsl
best of regards
what do l need to get the mlppp working?
dsl route in bridge mode or dsl interface cards?
dear all,
Please give me step by step to MLPP for PPOE Client with 1 line and 3 user id ADSL.
Regrads
Is it possible to use MLPPP with 3 DSL Lines?
THX
