3.11 "restore" erorr ?!
when do Restore in v3.11 I recived error “no file name”
clear install , and do backup, and do restore … and mt can’t do restore ?!
I do same with backup file from other mt router , it is same error ?!
I have the same problem after installing RouterOS v.3.11 on my RB433 and RB450… when I downgraded to ROS v.3.10 (on the RB450 device) I can restore my configuration from another routerboard config and the same device.
I have no problem with restoring on ROS 2.9.51 and 3.10 on the devices: RB112, RB333, RB433, RB450, RB500 and RB600.
ros bug
we need 3.12
Hi
I have problem with rtestore backup on RB600, hyper terminal returns:
rm: unable to remove `/tmp/restore’: Directory not empty, and RB don’t restore backup.
I try on MT V3.3, 3.9, on bouth the same action.
I too got problems with v3.11:
  1. the x86 machines get kernel panic message after rebooting form upgrade.
  2. this script doesnt work in netwatch, while it works in ROS v3.10 and below
/ip route set [/ip route find comment "Route 2"]  disable=no
I have the same issue with 3.11
the restore button is also missing in winbox under files
the restore button is there if you double click on the actual file. they just moved the button. however its broken in 3.11. MT confirms this will be fixed. for now i was able to use the CLI to restore a backup.
Hello, I would like to know which is the CLI sequence to restore a backup.
Thank you
/system backup load name=yourbackupfile
