settings:
band: 5GHz
frequency mode: regulatory domain
country: poland
on this setting after upgrade to 3.14 i have 5MHz step between channels but should be 20MHz
tested on mipsbe
settings:
band: 5GHz
country: poland
tested on mipsbe
Yes, it is new feature. Center frequency selection step is 5MHz now, not 20MHz as it was before.
Where is the changelog?
p.s. im voting for a more detailed changelog :>
the problem is that with radar dedection there are also channesl choosen that the clients can’t connect because they cant change thair channels in 5mhz steps !!!
Yes, default scan-list is used, where step is 20 MHz. DFS takes frequencies from scan-list.
5MHz scan-list would add delays to wireless operation, but you can modify scan-list manually and add frequencies with 5MHz step.
but also when i use 20mhz mode 5 mhz channels ar taken !!
if so - you loose connection !
i have problems too. when i set 5550Mhz the station did not connect (3.14) until in Scan List was aded 5550. Thats not good.
Inox, it means that 5500 frequency is not included in your regulatory-domain.
So I have to remember all the frecv. before I change the channel ![]()
Yes, because using an illegal channel might get you a hefty fine from the local authorities ![]()
