3.16 X86 100% CPU usage
I Just upraded an X86 box (details below) from 3.13 to 3.16. The machine rebooted fine, but after 10 Minutes CPU usage was still at 100%. As the unit had very little traffic at the time I wasn’t able to determine if it was actaully using 100% CPU or winbox was just reporting 100% CPU usage.
Downgraded to 3.14 - CPU usage now below 7% at all times.
Has anyone else had this problem, and or a fix?
hardware details (after downgrade to 3.14)
uptime: 14m12s
version: “3.14”
free-memory: 348980kB
total-memory: 452000kB
cpu: “AMD”
cpu-count: 1
cpu-frequency: 1607MHz
cpu-load: 6
free-hdd-space: 73117956kB
total-hdd-space: 76904380kB
write-sect-since-reboot: 34098
write-sect-total: 1021606794
architecture-name: “x86”
board-name: "x86
look at the green indicator in right upper corner of WinBox - it seems like it shows correct CPU usage even when text fields show incorrect for some reason…
3.16 = 5minutes working on a vmware server machine and then lockups
the green icon shows traffic from you to the router :slight_smile:
(O_o) ?..
why Janis didn’t tell me that earlier?.. ****! =(
seriously ? I thought that was the CPU meter for the past few years! Dang…
Let’s go back to this page (i updated it):
http://wiki.mikrotik.com/wiki/First_time_startup
Isn’t it great? Every day you can learn something new :slight_smile:
