3 -> 2.9 downgrade bug: firewall filter
Hello, there is another bug in routeros when downgrading from 3.0.xx to 2.9.xx:
when I had (in 3.0) last rule in firewall
chain=forward action=drop dst-port=135-139 protocol=udp
after downgrade it’s
chain=forward action=drop protocol=udp
-it simply clears port numbers (it happens only with last rule in firewall filters). last “tested” router had 3.0beta10 (I’m not sure, if it happens when downgrading from 3.0rc9 too)
Because in 2.9 you are unable to specify port ranges like 1-n.
mrz can you cite your source? I have a 2.9 box where I have rules exactly like fra’s. While I do not plan on upgrading and downgrading again. This is interesting and is worth looking into.
  1. Create backup before upgrading
  2. Upgrade
  3. Try what you need
  4. Downgrade
  5. Load backup.
No problems
Probably you are not talking about router os, because in mikrotik router os v2.9.x you CAN specify port ranges (I did it and I still do it on many routers) :laughing:
EDIT:
port ranges REMAINS in all firewall filter rules except the last one!
Yeah sorry just missed something. :laughing:
