3.20 out, but no changelog????
Am I missing something? or when I refresh the changelog for 3.20 http://www.mikrotik.com/download/CHANGELOG_3
It doesnt have anything for 3.20
try to refresh it a few more times :wink:
refresh and see
What's new in 3.20:
*) added support for IPsec hardware acceleration on RB1000,
   increases IPsec SHA1-3DES encryption from 45Mbps to 500Mbps
   and SHA1-AES from 79Mbps to 500Mbps;
*) fixed IPv6 on RB1xx and RB5xx;
*) added support for ZTE MY 39, CDMA EVDO USB card;
*) added clear-df action to firewall;
*) fixed bug - sometimes netinstall could fail to install RouterBOARD
   with "ERROR: could not format partitions";
*) fixed PCQ bug - pcq-rate < 70000 did not work correctly (broken in 3.17);
*) added radius-mac-format setting in hotspot server profile;
*) allow to use ip firewall for encapsulated PPPoE packets;
*) graphing - fixed 10Gbit card bug;
I can see it now, but it was not there before (tried on 3 computers)
good to see.
thanks
There some problem with new release version…
I mean about versioning there is no CHANGELOG about 3.19 on GERMAN mirror there is package 3.19 and no 3.20, but on LATVIAN mirror there is 3.20 version…
EDIT: It seems everything is fixed now :smiley:
it takes some time to upload it on all the mirrors and update all the pages.
Thank you! Finally! I’ve been asking for this since 2.9.26.
Sam
what’s this? =)
it will change an ip packet with df bit ( dont fragment bit) set to 0 .
Where is changelog for BIOS 2.19?
routerboard: yes
model: “411”
serial-number: “185F01F75C68”
current-firmware: “2.12”
upgrade-firmware: “2.19”
there isnt http://www.routerboard.com/files/rb-2.19/CHANGELOG
refresh that one too
Why only for MIPSBE?
what exactly ?
Why is new BIOS 2.19 only for mipsBE? RB4xx
it’s not, new Bootloader is for all versions of RB:
RB400: http://www.routerboard.com/files/rb-2.19/ar7100-2.19.fwf
RB1000 and RB600: http://www.routerboard.com/files/rb-2.19/mpc8548-2.19.fwf
thanks
if you upgrade your RouterOS to v3.20, you will be able to upgrade the bootloader too, just type “/system routerboard upgrade”. no additional download will be needed
Yes 3.20 makes my rb slow. Sometimes when i login with mikrotik and click on the wireless then the page will show no devices and then i will get a error saying routerboard got disconnected.
No. Show to my rb133
Could this be a WinBox problem? I have a similar - no ip route is shown when using WinBox 2.2.14 (copy from 2009.01.27 17:43 demo2.mt.lv) with RouterOS 2.9.51.Then I Exit and login again, - it’s working. :stuck_out_tongue:
